Home » Car Questions » 1996 Jeep Cherokee
1996 Jeep Cherokee
my oil light is still on after changing the oil and oil pressure sender
1 thought on “1996 Jeep Cherokee”
  1. you may have a bad connection or bad sender, possible the gauge us bad but not likely. check you connection at the sender first. Make sure there is in fact oil in it. and if you hear knocking or ticking noises that you don’t normally, you may want to have a pressure gauge installed to check the actual pressure.
    Does it go out when you rev the engine?
