Home » Car Questions » 1997 qx4 infinity
1997 qx4 infinity
it wobbles when you reach med to high speed.
3 thoughts on “1997 qx4 infinity”
  1. I took it back to the Tire X store where they were purchased with road Hazard warranty and they said they found nothing wrong with the tires and balance.. I since have replaced the rear shocks and front struts with no change. Im going to change the outer tie rod ends and go from there.It starts the wobble about 35 to 45 mph. sometimes it stops , other times i Look like a drunk driver.
  2. If you notice any increase while breaking or turning, it may be a warped caliper or hub bearing gong out. Make sure to check those as well. Sounds like you are narrowing down some things.
