When I have driver’s side air or heat on it doesn’t come out of vents as what it is suppose to. What is the part called and how do I install the part?
Keywords:Park Avenue
Mode Door Actuator assembly. You will need to disassemble the dash to get to it to test it and or see if something is cracked or broken.
Mode Actuator Replacement
Removal Procedure
•Remove the instrument panel assembly.
•Remove the driver air mix actuator.
•Remove the mode actuator retaining screws (1).
•Remove the mode actuator assembly.
