Home » Car Questions » 1999 Dodge Dakota Club Cab
Can the mechanic ruin the transmission when replacing the engine with a used engine? We were told the engine was shot. After replacing the engine with a used engine, the mechanic says the transmission is shot now. We had no warning that there was anything wrong with the transmission.
1 thought on “1999 Dodge Dakota Club Cab”
  1. Not very likely that a transmission be ruined by replacing the engine. I am thinking why was the engine shot? Was it in a flood, then it would be quite probable that the transmission would also be damaged.
    If the transmission was working just fine before you blew up the engine, I wouldn’t think just by replacing the engine that it would no longer work. Was it working before? and what happened that caused you to replace the engine?
