Home » Car Questions » 2005 Ford Focus 5 dr
Had the axles replaced last FRiday becuase the CV boots were torn. Saturday the transmission would not come out of 2nd gear. Checked fluid, added 1/2 quart and check engine light came on. Mechanic that did the axles say this is not connected to his doing the axles. Coincidence and seperate problem. I don’t think I believe that. Opinions ???
1 thought on “2005 Ford Focus 5 dr”
  1. The check engine light would not come on for anything mechanical such as a cv axle shaft. The Check engine light is connected to the electronics of the engine. Find out why the check engine light is on and post the codes below for further information. Just about any local auto parts store will pull the check engine light codes for you at no charge.
