I had my oil changed about a month ago. The mechanic said that the noise I was hearing on the front drivers side was a leaking seal. He said that eventually I would have to replace the bearing. I am trying to figure out if this is the wheel bearing or the axle shaft bearing.
Keywords:Patriot
The axle shaft bearing would be at the transmission and the wheel bearing (hub bearing) would be at the wheel. Most hub bearing do not leak anything… I would look for signs of leaks on the ground where you park to see if in fact something is leaking. The Hub bearing is a common failure part, more sop than that of the axle bearing.
