Home » Car Questions » 92 f250 5.8 4×4
92 f250 5.8 4×4
do I really need to take off the upper intake and throttle body to remove the oil pan?
1 thought on “92 f250 5.8 4×4”
  1. According to the Repair manual procedure, YES.
    Myself, I wouldn’t think you would need to. I would try get by without if I could. I have done this job before on a F150 and do not remember removing the intake at all, but you do have to unbolt the oil pump and pick up tube and drop it into the pan before you can pull the pan out.
