Car was stalling when the clutch was pressed. Then died going down the road. Changed the distributor and coil. Checked the fuel pump. Still not starting but it turns over
97 honda civic
Keywords:civic
You will need to determine if you are not getting fuel, spark or timing. If you are getting fuel and spark, may be a broken timing belt… does it sound a little different when cranking it over?
