car wont start did but intermittant and would stall after a few secondsseemed to start on fuel from pump priming ,cleaned tank, flushed lines,now wont fire at all engine check light flashes constantly any ideas
First you will need to determine if it is not getting fuel or spark. Then you can isolate that area and concentrate on the issue. If you have spark, try starting it on starting fluid. If that works, you know it is a fuel related issue.
