Home » Car Questions » 1974 ford mustangii1974 ford mustangiiJune 28, 2015No “juice” to horn,lights,,ignition. Battery is goodKeywords:Mustang 21 thought on “1974 ford mustangii” Freeautomechanic June 28, 2015 at 9:15 pm All you can do is check the fuses and trace the wiring. Most likely reason would be loose or corroded connections at the battery terminals. Those check out, check for rust connections of the ground cable.Comments are closed.previous2004 Mitsubishi eclipsenext88 ford mustang lx
