Home » Car Questions » 1984 chevrolet c10 silverado 305 v81984 chevrolet c10 silverado 305 v8June 22, 2015where is oil sender located and how to test it?Keywords:silverado1 thought on “1984 chevrolet c10 silverado 305 v8” Freeautomechanic June 23, 2015 at 6:42 am It is located by the distributor mounted in the engine block. If you see oil around it, that means it has a leak ans should be replaced. This is a common failure component and is inexpensive. Takes a special socket to remove it. Comments are closed.previous2000 F250, 6.8L ENGINE, ATnextpantiac firebird 96
