I have a 1997 audi a8 Quattro with 180,000 miles on it and for a while now the power and acceleration has been horrible ……i have to push down really far on the pedal for a while to get it up to a descent speed …and its kinda embarrassing ….especially at lights or a stop sign……freeway driving isn’t that bad but i can tell the power is nothing what it should be …..im thinking it could be the plugs or possible maf sensor but i changed the plugs about 5 months ago …..there is no check engine light on and no codes being thrown at all …..please help!!!
If the engine sounds different than it used to then you may have a failed coil. If it sounds the same just under powered, it may be a fuel deficiency possibly cause by lack of fuel pressure, clogged fuel filter or dirty MAF.
