Home » Car Questions » 2000 F250, 6.8L ENGINE, AT
MY 15AMP FUSE TO HORN KEEPS BLOWING. I REPLACED SQUARE RELAY ALSO.
1 thought on “2000 F250, 6.8L ENGINE, AT”
  1. A fuse blows when there is a short in the system. Unplug the horn and replace the fuse. If it blows the problem is in the wiring, if it doesn’t blow until you plug in the horn, most likely the horn is shorted internally.
