I just bought a 2000 Toyota Camry and took it to get smoged and it failed due to code p0770, how can I fix it or what needs to be done to be able to pass smog
2000 Toyota Camry
Keywords:Camry
P0770 Toyota – Shift Solenoid ‘E’ Malfunction
The ECM uses the signals from the Throttle Position Sensor and Air flow Meter to monitor the engagement condition of the lock up clutch. Then the ECM compares the engagement condition of the lock up clutch with the lock up schedule in the ECM memory to detect mechanical trouble of the shift solenoid valve SLU, valve body, torque converter clutch and automatic transmission assembly
Possible causes
– Low transmission fluid level
– Dirty transmission fluid
– Faulty shift solenoid ‘E’ valve
– Shift solenoid ‘E’ valve harness is open or shorted
– Shift solenoid ‘E’ valve circuit poor electrical connection
When is the code detected?
The P0770 code is detected when Lock up does not occur when driving in the lock up range (normal driving at 80 km/h [50 mph]), or lock up remains ON in the lock up OFF range.
