I am having an issue starting my 2001 Subaru Outback. I have replaced the battery and alternator within the past month, thinking that they were possibly the source of the problem. When I try to start the vehicle I do not hear clicking or any other distinguishable noises.
Keywords:Outback
Check your connections at the battery and make certain the battery is fully charged. If that all checks out, then check for battery positive at the “S” terminal on the starter while someone holds the ignition key in the “START” position. If you see battery positive, replace the starter.If not, trace the wiring back.
