car has 1/4 tank of gas.it will start if you turn key on and wait 30 seconds.will run for about 30 seconds and then it will die.
Keywords:trooper
Have you tried adding fuel to the tank to make sure the gauge isn’t broke and its just out of gas? Does it loose fuel or spark and does it start right back up? Check engine light on, any codes?
