Do you have an aftermarket radio? It may be drawing to many amps from the alternator and not able to keep up with the aftermarket setup. May have a weak battery and or alternator. Also make sure there is no corrosion at the battery connection terminals. Bad connections create resistance that prevents the battery from being properly charged.
