Home » Car Questions » 2006 honda crv
2006 honda crv
My car has a flashing D , indicator light on the dashboard when the lever arm is in park “P”, after I drove a mile or more?
1 thought on “2006 honda crv”
  1. The flashing “D” indicator on your dashboard indicates that there an electronic problem with the transmission’s electronic controls. Failure to rectify an electronic problem promptly can easily lead to much more expensive mechanical repairs to the transmission. (from your owners manual)
    I strongly suggest that you NOT take the car to AAMCO unless you want to be told that you need a new or rebuilt transmission–whether you really do or not. The chain transmission operations (AAMCO, Brownies, Cottman, Mr. Transmission) are known for giving the most dire diagnoses, charging the most, and delivering poor workmanship.
    You should take the car to an independent trans shop that has been in business for at least 3 years. Ask friends, neighbors, relatives, and co-workers for referrals to an independent transmission shop in your area. In addition to being cheaper and more competent/more honest than a chain transmission shop, the independent shop will likely also be cheaper than the Honda dealer.
    Source: VDCdriver
