Home » Car Questions » 87 f 150 efi inline six
Im having a problem starting my truck its acting like its not getting enough power but ive replaced the battery,soleinoid,spark plugsand starter do you think its the cable that runs to the starter from the soleinoid?
1 thought on “87 f 150 efi inline six”
  1. Weak battery or too small of a battery. Small(if a modified engine), corroded or loose cables and may also be if the timing is too far advanced. Bad connection of cables on power or ground, worn starter.
