Home » Car Questions » 1978 GMC K-1500 4wd
1978 GMC K-1500 4wd
Temperature Gauge not working. I have tested the gauge to see if it would “ping” out all the way when I ground it to the block. It did, so that should mean the gauge is functioning properly. I have also replaced the Temperature sensor switch with 3 separate ones but still the gauge is not working
1 thought on “1978 GMC K-1500 4wd”
