Home » Car Questions » 1988 Honda Accord LXi manual transmission
What is the flat rate repair time for:
1) remove and replace power steering rack and pinion gear assembly
2) remove and replace power steering high pressure hose/line
Does doing these 2 procedures together reduce the total time?
1 thought on “1988 Honda Accord LXi manual transmission”
  1. Rack and Pinion : 4.2 hours
    Pressure Hose : 3.2 hours
    Together might reduce a little but not much if at all. The age of the vehicle may actually call for longer time as it is old and rusty and may require more time.
