My 700r4 tranny went into limp mode due to a burnt 3-4 clutch. I bought a 2wd 700r4 (same year) for cheap with low miles. I want to know what I need to do to be able to drop my current 4×4 tranny and install the new 2wd 700r4 to convert it to 4wd. I have all parts for the 4wd.
From what I understand the tail shaft is a different length and the tail shaft housing is also different and will not work. If you are just looking for removal and replacement procedure you may request the auto repair manual procedure here:
Auto Repair Manuals
