I recently change the transmission it is a manual 4 speed over drive everything was fine for about a week or two.Now the the speedometer,odometer and the trip button is not working at all
Check your connection on the side of the transmission to the speed sensor gear assembly. Make sure the cable is securely attached. If the cable is good and the gear is good, check the connection at the gauge assembly. If that checks out, the last thing would be to replace the gauge.
