There was a leak in the fuel line and after I fixed it the gas won’t go through the fuel pressure regulator why is this is there a way to fix this without buy a new fuel pressure regulator is there a way to take it apart and clean it or something?
Keywords:truck
Make sure you didn’t fix it too good. A you certain fuel is flowing to the regulator..If yes, then You will need to replace the fuel pressure regulator.
