Home » Car Questions » 1997 MERCEDEYS BENZE E-420
REPLACED FUEL PUMP THREE TIMES WHEN IT DRIVES IT HAS NO POWER WHAT COULD THIS BE
1 thought on “1997 MERCEDEYS BENZE E-420”
  1. Could have a clogged catalytic converter. Did it make a difference after replacing the fuel pump the first time? Have you checked the fuel pressure and or the fuel pressure regulator? Did you also replace the fuel filter?
    Check engine light on? any codes?
