Hi I’m having this problem where my car had a dead spot in the throttle. No matter if it’s in park or drive or whatever, it runs perfectly fun before and after about a 1/4 throttle but when you hit that spot it just cuts out but passes it and is fine. It’s not intermittent it does it every time no matter what. I will give further info if needed but I just can’t figure it ou, any help would be appreciated thank you
1997 Mercury Cougar xr7 with the 4.6
If the check engine light is on, please get the codes and post them below in the comments.
My first thought would be the TPS – Throttle Position Sensor sticking or hanging up a bit.
or maybe the throttle cable(check the movement by hand at the throttle body itself.)
