It came from the factory with a 2.0L 4 cylinder or a 2.5L 6 cylinder engine. You can put just about any engine you want as long as you are willing to change everything over to make it work. This would cost thousands of dollars and require lots of fabricating. For you to change the engine to anything other than what came in it, you are looking at replacing the computer system, wiring, ignition, exhaust, transmission, mounting, etc.
