the car will run for about 15 Minutes and then stall, I have 3 different people who have looked at it, some say its the alternator, 1 has said the fuel pump, and one said the cat converter, what would cause this
Does it start right back up? If not, you can do some testing to see what is missing when it will not start.
You can still hook up a meter tot he alternator and monitor the charging system to see if charging quits just before it dies. You can hook up a fuel pressure tester and watch to see if your fuel pressure drops just before it dies. And a back pressure tester can be hooked up to check the catalytic converter to see if it is clogged.
Fuel Pressure Tester
Back Pressure Tester
Alternator Tester
