Home » Car Questions » 2002 Ford Expidition
I was putting in a wireless back up camera when out of the blue when you only have the doors open the interior and running board lights start flashing . I can hear the flasher relay working.I disconnected the battery to see if it would reset itself and it did briefly. Also the delectric door locks and windows quit working. I checked all the fuses and they are all good.
1 thought on “2002 Ford Expidition”
  1. I would start with your resent work to see if you crossed a wire or shorted another when hooking up the camera. If that checks out, check your hazard switch to see if it is sticking.
    Did you check the fuses under the dash and under the hood?
