My power Windows will not roll up or down
My power lock or mirrors are not working
I’ve checked all fuses they are good
Could it be the motor or a plug on the inside of the door?
Both the locks and windows use fuse 12 and 6 so double check that first. Then trace the wiring to see if you have power to the door switch. Power at the fuse but not at the switch would most likely be a broken wire at the door jam.
