Home » Car Questions » 2002 Volkswagen Passat
My daughter just had her alternator replaced on a 2002 Volkswagen Passat. After she picked up her car from the shop the stereo is dead. No lights, nothing. Its not the security code because it doesn’t even work to input the code. She took It back to the shop they checked her fuses etc. They said it has nothing to do with them replacing the alternator and is not their problem. Which I understand to a degree, but the stereo worked just fine before the service. Am I crazy to think it might have been something they did?
1 thought on “2002 Volkswagen Passat”
  1. Shouldn’t be related at all. The possibility of them shorting something out would cause the built in fuses to blow before any damage could occur to the radio. I would have a different shop check the fuses or for the reason it does not work. I am also assuming this is a factory installed radio and not an aftermarket radio.
