Home » Car Questions » 2004 Nissan murino
2004 Nissan murino
Replaced battery now car won’t run no longer then 5 mins n cuts off …turn key and it starts perfect but cuts right back off..turn key again cuts off..
1 thought on “2004 Nissan murino”
  1. Try this.
    Disconnect battery, put key in ignition and turn it to the “ON” position and then reconnect the battery. Move the key from “ON” to “START”. This should reset the anti-theft if it is causing the problem.
