Home » Car Questions » 2005 ford taurus
2005 ford taurus
have a 2005 taurus check charging system and batt light keeps coming on have changed alt and batt and also the 175a fuse under the hood and still doing the same thing.
1 thought on “2005 ford taurus”
  1. First you will need to test the charging system and battery to see if the alternator is charging. You can do this by attaching a volt meter or tester to the battery.
    If you see that it is charging OK, then the issue would be Battery light indicator or wiring to it.
    If the alternator is not charging, then the alternator or wiring that connects to or from it needs repaired.
    Alternator Testing
