Home » Car Questions » 85 chevy g20 van 5 liter
i had a front end alignment done because of a pull 2 the right after the alignment i still have the pull after a tire rotation i found out the tire rods were never adjusted, should they have been adjusted!!!!
1 thought on “85 chevy g20 van 5 liter”
  1. Only if they needed to be and my guess is the tire had a busted belt and needed to be replaced and was the cause of the pull in which case the tie rods would not need to be adjusted.
