Home » Car Questions » 95 ford contour
95 ford contour
I have a 95 ford contour the person before me had a bunch of wires rigged to the fan and a toggle switch that would always drain the battery is there a fuse that would go to it or how do I fix this issue
1 thought on “95 ford contour”
  1. Locate a fuse or power supply that only has power with the ignition key on. Then attach your power wire from it to the toggle switch or eliminate the toggle switch altogether. The the fan will only operate when the key is on. Make sure to install and inline fuse. The original cooling fans used a 60 amp fuse located in the engine compartment fuse block which provided power to the low speed relay and the high speed relay. Those relays would then provide power to the fan/s.
