It wont start, has fuel to the engine, has good spark plugs and wires and cap and rotor, has a new distributor, has a new starter.
98 Chevy Blazer
Keywords:Blazer
You will need to determine what the engine is not getting.
You need 4 things to make an engine run.
![](data:image/gif;base64,R0lGODdhAQABAPAAAMPDwwAAACwAAAAAAQABAAACAkQBADs=)
![](data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIxIiBoZWlnaHQ9IjEiIHZpZXdCb3g9IjAgMCAxIDEiPjxyZWN0IHdpZHRoPSIxMDAlIiBoZWlnaHQ9IjEwMCUiIGZpbGw9IiNjZmQ0ZGIiLz48L3N2Zz4=)
1. Fuel – need fuel pressure and INJECTOR PULSE
I use one of these to check for fuel injector pulse. No need to unplug anything. Just touch the tip to the side of a fuel injector and have someone crank it over. If it blinks, the injector is pulsing. No blink = No Pulse. Simple and easy.
Follow the image for more Details….
2. Spark – Make sure you see spark at the plugs. Use a spark tester.
3. Compression – What is compression
4. Timing – All of the above 3 at the right time.
Make sure the ECM fuse is good.
No Start Diagnostics
