The car is overheating .we replaced the radiator cuz it was cracked. Then replaced the thermostat. Its still overheating. I know it could be water pump but what’s other possibilities
First thing would be to make sure there are no leaks (pressure test the system)and that the system is full on coolant. Then you would want to confirm the engine is actually overheating by using an external gauge. Then you can monitor when the electric fan is coming on or if it isn’t coming on at all.
