Home » Car Questions » infiniti 2003 fx45
infiniti 2003 fx45
how do you replace the control knob cover
3 thoughts on “infiniti 2003 fx45”
  1. Push down on the ring on top of the shift boot. It should slide down.
    Next there is a clip at the bottom of the shift knob. It was under that ring you pulled down. Pull that clip off.
    The shift knob should then pull off.
