Home » Car Questions » Mazda b4000 2002
Mazda b4000 2002
Steering tried to lock and now pop while turning
1 thought on “Mazda b4000 2002”
  1. sounds like something is binding up. Make sure the fluid level is full. If it is low, find and repair the leak. If it is full, you will need to check the steering components. Have someone turn the wheel while you inspect and listen. Replace as needed. Could be a busted or loose tie rod end or may be the STRUT and or strut spring.
