i only get one squirt of fuel out of feedback carb when trying to start no more than that and vehicle won’t start
Keywords:Cherokee
Try seeing if it will start with starting fluid. If it does then you know it is only fuel related. You can check fuel lines and if they are OK, you are probably looking at replacing the fuel pump.
