Must I remove the pulley in order to remove the power steering pump, or can the bolts be removed w/ the pulley staying on? The Haynes manual says that some require the pulley removed and some don’t. I’ve heard both ways from other sources too, I need help, please!?!
If there are holes in the pulley that allow you to access the bolts through the pulley…. then you do not have to remove it. If there are no holes, the pulley needs to come off. It isn’t to difficult to remove the pulley if you have a puller.
Follow image for more Details…
