I replaced both the battery and alternator , both were confirm needing replacement at auto zone,, but for some reason the battery light came on and the gauge show that the battery is not receiving/holding the charge from the alternator and it quickly drained the new battery, which is now dead. I checked the wiring connections on both the battery and alternator. I don’t know what else to do or check. What else could be the problem?
Keywords:mustang
If you are certain the alternator was connected and installed correctly, the NEW alternator may be bad… it happens. More often than you would think.
The good news is, Autozone is pretty good about covering the product warranty.
