1998 Buick Skylark
I recently replaced all brakes on the car. The pedal feels spongy and its VERY difficult to come to a stop. The abs light and ets off light is on. I’m not sure if I’ve bled them correctly. Please help
1 thought on “1998 Buick Skylark”
  1. Did the pedal feel this way before and is the reason you decided to install new brakes?
    If it was, it may be a brake caliper hose damaged or weak and is flexing.
    Not sure why you needed to bleed the system but since you already did, this may be the problem. You need someone to help you do it. Start at the furthest corner and work your way to the front.
    Brake Troubleshooting
