The front of my car is jacked up, both front wheels are free from the ground, when I turn one of the wheels should the other one turn as well?
I ask because I’ve just changed the drivers side front driveshaft completely and since then I’m getting knocking, banging and vibration on both sides of the driveshaft! what can it be???
If the issue wasn’t present before and now it is, you will need to go over your work to see what you did wrong or forgot to do. You should be able to hold one wheel and the other side should turn and the same for both sides. If it doesn’t something is bound up.
