Truck won’t start, I don’t hear the fuel pump running. I’ve checked the fp relay and it clicks when you turn the key. Have removed the fuel line from the fuel filter and turned the truck over but no fuel is pumping from the tank.
Keywords:silverado
You will need to confirm you are getting power and ground to the fuel pump. If it is and you have no pressure, then you need to replace the fuel pump. This is a very common failure part on this vehicle.
