Home » Car Questions » 2004 pontiac montana FWD
i tried to check trouble codes and the scanners i tried could not connect to the PCM. but the check engine soon light was on and when i gave it gas the lite blinked
1 thought on “2004 pontiac montana FWD”
  1. Blinking or flashing check engine light is not good. Need to find out the codes for sure. Most scan tools will not connect if there is a blown fuse. Usually the radio or cigar lighter fuse. If you suspect your scan tool, take it to just about any local auto parts store and they will scan the codes for free (of course in the hopes of selling you a part).
