I Just has my starter and battery replaced in my car and yesterday I go to turn start my car and nothing I checked the fuses the starter and the battery which is at 12.5
Keywords:neon
The battery can show 12.5 volts and still be to weak to start the car. You need to confirm battery voltage at the “S” terminal on the starter while someone holds the ignition key in the “START” position. If you see battery voltage(and the battery load tests good) replace the starter. (possible to get a bad NEW part)
The battery needs to be load tested to insure it is good. Using a 100 amp load tester works well for this. This is what I use.
