Home » Car Questions » 2006 dodge dakota quad 4.7 ho 4×4
Every now and then I have to rev up the rpms for the truck to start going. Once it gets going it’s fine. Any suggestions? I’ve changed transmission filter and seal already. Thanks
1 thought on “2006 dodge dakota quad 4.7 ho 4×4”
  1. Sounds like your transmission is slipping form what you have described. Make sure the transmission fluid level is full. If it is and it looks dark(when you replaced the filter), you are looking at a rebuild.
