Home » Car Questions » 2006 VW Jetta
2006 VW Jetta
I need help! My 06 Jetta will not start. It will not turn over and the brakes have become extremely hard to push. Lights and all come on. Tried to jump it to no avail. What could it be?
1 thought on “2006 VW Jetta”
  1. Most likely reason would be the battery. It doesn’t take as much juice to turn on the lights as it does for the starter to turn over the engine.
    When you turn the key to “start” does it make several clicks?…. Replace Battery
    Does it make one hard click? Battery, connections, or starter issue.
    New battery then You can check for battery positive at the “S” terminal on the starter and if you see battery voltage, replace the starter.
    No Start Diagnostics
