Home » Car Questions » 2007 Volvo C70
2007 Volvo C70
Drivers door window will lower when door is opened. When the door is closed the window will not go back up as Volvo windows do when convertible door is opened. I have to raise window with door switch every time I enter car. Window only drops down about a 1/4 inch as it always did. Does door window switch need replacement?
1 thought on “2007 Volvo C70”
  1. I would lean more toward the door latch switch. If computer thinks the door isn’t shut, it wouldn’t allow it to go up automatically. I am going to assume the problem is on the drivers side only and the passenger side works as it should.
